Homemade Reverb Ste...
[Closed] Homemade Reverb Stealth ports
[#5317068]
Anyone fitted a stealth to a non-stealth frame? Any issues?
Posted : 09/07/2013 2:20 pm
Obviously it'd void your warranty - but should be OK - just speak to a framebuilder to figure out where you can drill a hole in with out much worry -
Posted : 09/07/2013 2:52 pm
There's a "Bike check" over on VitalMTB where some bloke drilled his carbon Nomad - he did it on the side of the down tube. He was a pro (ish) enduro racer, and was still alive.
Posted : 09/07/2013 2:56 pm
Two Nomads:
[img] ?1354829177[/img]
[img] ?1369512753[/img]
Posted : 09/07/2013 3:00 pm
A bike shop mate has done it a fair few times, they are a Specialized dealer do you want me to ask if he has done a Pitch before?
Posted : 10/07/2013 10:17 pm
I've done my Rumblefish on the front of the seat tube where the second set of bottle cage mounts would be if it had them. No issues so far
Posted : 10/07/2013 11:59 pm
Amazing Ibis Mojo HD mode, he's a brave man!!
Posted : 11/07/2013 9:05 am
 womp
Managed to route all the way down the down tube and up the seat tube with-ought removing the bottom bracket, looks neater than most Stealth ready frames TBH
Posted : 11/07/2013 10:38 am
Running 1x10 meant I had a spare 'port' in the frame due to the internal gear cable routing of my PIVOT-LES.
I knocked up new cable guide to suit the larger diameter of the hose and threaded the hose down the downtube and up to the post et voila...
Posted : 19/07/2013 4:31 pm
