Homemade energy bar
[Closed] Homemade energy bar
[#7469618]
Want to make it a bit cheaper and make my own.
Any good recipes that I could use?
Posted : 21/11/2015 12:12 am
just grab a flapjack recipie off the bbc good food, make it as lean or as sugary as you think you need
porridge oats, sultanas, smashed up nuts, bind it together with melted butter, honey or treacle or whatever sucrose if you want, mix it all together, lay it out on a papered tray and oven
tip, when cold and cut up, wrap in more greaseproof paper and use masking tape to stick the folds, easy to tear open when on the go
Posted : 21/11/2015 12:55 am
http://singletrackworld.com/forum/topic/wanted-to-share-a-great-homemade-energy-bar-recipe-i-found
I've been using this for a while. It's got roughly the right ratio of carb and protein if you work out the size you need per hour. Recommend using really good peanut butter.
Posted : 21/11/2015 7:38 am
Made a batch of these, they are nice
http://cyclingtips.com.au/2015/11/the-training-foodies-peanut-butter-oat-slice/
Also rice cakes work well (can do sweet or savoury)
http://feedzonecookbook.com/?s=allen+lim%27s+rice+cakes&submit=Search
Posted : 21/11/2015 8:59 am
