Home made cable rub...
[Closed] Home made cable rub protectors ..any tips/ideas on materials /+ fixing?
[#503399]
thought of using bits of old inner tubes but unsure about the adhesive to use without damaging the frame if i wish to remove.
any other ideas?
thanks
Billyboy
Posted : 26/04/2009 7:24 pm
I use a cable tie on my fork with another cable inside it at 90 deg to stop it rubbing. Seems to work.
Posted : 26/04/2009 7:26 pm
For just protecting the frame from cables and hoses I went to a firm that silk-screens signs and scrounged some off-cuts of a thickish clear permanent s/adhesive vinyl and just cut bits out to fit. You could get hold of some helicopter tape to protect the frame and use off-cuts of that where the cables and hoses touch the frame. On my bare steel Inbred I used a piece of inner tube wrapped around the chainstay and zip-tied to protect from chain slap.
Posted : 26/04/2009 7:37 pm
puncture patches, free stickers, insulation tape
Posted : 26/04/2009 9:01 pm
gaffa tape
Posted : 26/04/2009 9:03 pm
