Just curious after hearing about some home filling kits, anyone tried these or any other more adventurous proceedures?
Of all the things to save money on, i suspect dentistry is probably one of the worst.
Aren't those home filling kits basically designed for emergencies? Sort of thing you'd take if you were spending 3 months treking in Nepal or racing to the North Pole or somthing.
My future Wife's father used pliers on his kids to remove loose teeth.
I can give you his number if you want.... 😯
Damn that wasn't the gorefest i was after, i thought with all the sucsessful bike bodgery the STW lot would of at least attempted a few Dremel aided root canals. 😆
tooth removal via twine and a door handle ....
Mmm home dentistry is not a good thing, Mrs C used to work as a dental nurse. Had a patient come in 1 day he didn't want to pay to have a tooth removed, said he could do it himself, a few weeks later she see's him and finds out he tied a weight to it, threw the weight out of the window and broke his JAW!!!.....tooth still in place.
AARRRRGGGHH!!!!
im not a rich man but.....if you can afford a bike, you can afford a dentist!
The string and door handle method, reminds me of Tony in men behaving badly doing that. 😆
[url= http://www.veoh.com/group/men-behaving-badly#watch%3Dv18542716r5PxKfS6 ]About 6:50 into the episode[/url]
We had a chap come into A&E who had tried to smooth off a cracked tooth with a dremel and less than steady hands 😯
After working in Central Queensland, where dentists are very scarce, I bought some stuff to put on your teeth if you ever got a bad case of tooth ache. It is only a temporary measure, giving enough time to try and find a dentist and a good few hours drive to the dentists surgery. My wife used it once, and it worked.
I also know a bloke back in the UK who had a tooth ache at work, went to the workshop, got a pair of pliers, and you can imagine the rest!
worked with a guy who used to use superglue to stick crowns back on and fillings back in!! said he had a lab coat and therefore qualified!
I've tried the temporary crown cement you can buy in Boots before. Dentist said it actually made a permanent reattachment harder and it only laste 2 days in any case before it fell off again!
DIY dentistry....kind of in the same league as DIY circumcision, i.e. its a no brainer!
I had a dentist remove a wisdom tooth and he hurt me so much I wouldnt go back, took my own stitches out, this might have proved quite addictive as I have in the past tidied up a filling with some wet and dry paper as it used to snag food, much better now.
I DRAW THE LINE HERE, I WOULD NOT DO MY OWN FILLING AND DRILLING!!!
Agree with Tinsy. A bit of filing and wet&dry on jagged bits OK, nothing more.
DIY dentistry....kind of in the same league as DIY trepanning, i.e. its a no brainer!
My brother filed his front tooth down after he'd chipped it.
