Hollowtech rounded ...
[Closed] Hollowtech rounded pinch bolts replacement advice
[#788202]
Hi, my pinch bolt (soft as cheese!) was rounded off, dutifully I drilled it out and managed to remove the crank (part fc-m760) but destroyed it in the process, woops, I found replacement (hope its the right one)
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=12509 ]replacement crank arm[/url]
but does anyone know when i can get some good quality pinch bolts ? or anyone use some good replacements ?
many thanks
Posted : 15/08/2009 7:04 pm
The Shimano ones are perfectly fine. If you managed to round them then you either did them up far too tight or used a really crap allen key.
Posted : 15/08/2009 7:44 pm
Merlin are Doing XT M770 complete chainset for £120 (better chainring's & spare bottom bracket?)
Posted : 15/08/2009 8:29 pm
