Dear All,
Following a thread on here about b/b, chain line and preventing chainsuck, I've taken a look at my bottom bracket after fitting a new chain. It's a 73mm frame shell and I've been told it should have a 2.5mm spacer installed on the drive side, twixt frame and b/b cup.
Am I right in assuming I can actually see this spacer?
i.e. it doesn't fit inside the cup, hidden away internally?
....so I should be able to see frame edge-spacer-b/b cup.
I don't think my lbs has fitted one when setting up the bike, and having been slightly prone to chain suck, I'm thinking of going back and getting it sorted. That and a new chain should help - anything to get away from the dreaded suck!
thanks all.
Q
cool - glad to be of help 🙂 I am sure I speak for everyone 🙂 You should def have a spacer on teh drive side with a 73mm bb width unless its a strange chainline ?
[i]Am I right in assuming I can actually see this spacer?[/i]
yes, should be an obvious seperate ring between the BB and the frame.
Just popped out to double-double check, armed with torch and glasses!!!
Yes I see it!!! Hurrah!
I suppose I was looking for a silver ali type ring, whereas it's actually a black ring as above. When you've a black frame it isn't immediatly obvious. I thought the end of the b/b shell was ring reinforced, then realised it was only on one side - duhhhh
OK sorted. Got one, sorry lbs for doubting you!
thanks to all
Q
