Holdsworth Elan siz...
[Closed] Holdsworth Elan sizing
[#10305104]
Anyone got one of these frames? How are is the sizing on them? i'm about 5"9 so inbetween the S/M i think...
Posted : 31/10/2018 11:19 pm
I'm on the L to XL border with Holdsworth frames. I look at the top and head tube lengths next (in that order) and compare to a known well-fitting frame
Posted : 01/11/2018 8:25 am
I have a stelvio and am 5'7" just about and I'm on a medium
Posted : 01/11/2018 8:54 am
Mild HiJack
Has anyone tried some larger tyres in the Elan?
I think the spec sheets says 28mm max, but is that 28mm with nice clearances and mudguards or 28mm just barely getting in and less if you want mudguards ?
Thanks
ps slightly on topic - this the only frame ever that suggests that I am on an XL frame - strange
Posted : 01/11/2018 9:01 am
 jwt
To answer both questions -
I'm 5ft 5in and on a 48cm.
28mm will go on a 48 but they are tight and I had to do some serious fettling including quite a substantial bit of filling on the front mech to get everything to fit and still be able to change between front chaining's.
It may be a quirk of a small frame that there isn't a lot of space between the rear wheel and the seat tube but it may be worth looking on the bigger frame sizes?
Drop me a line if you want me to take a photo?
Posted : 01/11/2018 9:17 am
 jwt
I should add that was with some 45-55mm mudguards!
Posted : 02/11/2018 9:22 am
