Hex skewer help…
Hex skewer help…
[#12813819]
Looking to buy some of these for a build
https://www.halowheels.com/shop/components/skewers/hex-key-skewers/
Problem being I need an xl for the rear and a regular one for the front (bike is 100mm up front and 135mm plus tuggnuts either side at the rear)
Budget is getting tight so I don’t particularly want to buy two sets but if I HAVE to then I’ll have to suck it up
Does anyone know where I can buy these singularly or recommend a different brand of decent quality that come singularly in varying sizes?
TIA
Posted : 06/05/2023 3:05 pm
Just bought ordered some of these myself today for the pub bike. I went with M Part security ones, they come in both road and MTB/Hybrid, I believe the latter is 100/135. Wooly Hat have them at £14.99 posted.
Pretty sure the ones I'm replacing were M Part, over-tightening killed them after 15 years abuse.
Posted : 06/05/2023 4:06 pm
I had the same problem with Boy1s Inbred. I think I got the XL set but with a standard front.
I might have a bolt in the spares box. I’ll have a look and you can have it if it helps.
Posted : 06/05/2023 7:57 pm
Those look shinier than the steel nuts and bolts I have on my old commuter and old
Posted : 06/05/2023 8:16 pm
@bigblackshed is that a thing?! Mix and match as it were?! I can only seem to find xl set or standard set and only in sets, I might be looking in the wrong places but stuffed if I can find any different
Posted : 06/05/2023 8:22 pm
@donslow
Checking in the bits box. I have some Halo Hex skewers in red.
Front will do 105mm to 125mm.
Rear will do 132mm to 150mm.
I also have a non-Halo bolt that will do 102mm to 117mm.
Does any of that help?
Posted : 08/05/2023 7:36 pm
@bigblackshed you have a PM incoming sir
Posted : 08/05/2023 8:43 pm
