Helvellyn trails - ...
[Closed] Helvellyn trails - anyone know this particular one?
 wl
[#4398453]
Sorry I don't have a map ref or anything, but as you approach the top of Dollywagon Pike from Helvellyn's summit, just near where the actual Dollywagon proper descent starts, there is a metal pole (I think) and what looks like a trail going off to the right (possibly it's not even marked on a map, or it might well be footpath). Anyone know it, and whether it's at all rideable or even worth a look? And where does it come out? Looking for an alternative to Dollywagon itself - don't mind if it's sketchy, exposed, techy. Ta.
Posted : 25/09/2012 3:28 pm
 wl
Anyone?
Posted : 25/09/2012 4:06 pm
No sure about that one, but there are several steep paths up from Thirlemere alongside gills that you wouldnt want to ride.
Just looked at an OS map, is it the bridleway that runs down to a phone box marked on the map - that looks interesting, but never read anything about it, or even walked up that way
Posted : 25/09/2012 4:14 pm
 wl
Agent - thanks for this. I'm not sure which one it is - I didn't know there were several and a friend told me about this one - I've done Dollywagon a few times but never noticed it on my way past. I do know there's a good BW that veers off to the right as you follow the flat approach to Dollywagon from the summit. Steep, then flattens out and drops into some woods before you hit the road alongside Thirlmere. I can never remember it's name.
Posted : 25/09/2012 4:18 pm
That's probably the trail I can see on the map. I know why you're asking, you dont want to waste a 800m climb with a pants descent. I'm next up that way at New Year, not normally rideable then unfortunately. More ice axe territory.
Posted : 25/09/2012 4:21 pm
Sticks pass down to Legburthwaite is a great rip in the dry..
I went up via Comb crags.
Posted : 25/09/2012 4:24 pm
 wl
Done Sticks down to Glenridding, do you mean the other way, Freeride? Do you happen to know the trail I'm on about?
Agent - bang on, don't want to waste the climb. Up there in a couple of weeks and looking for an alternative to Dollywagon, preferable that leads to the road between Thirlmere and Grasmere so we can then push back up to Grizedale Tarn and do the cracker to Glenridding.
Posted : 25/09/2012 4:30 pm
This post? It's an old gatepost from a fence that was there years ago...quite a well known local landmark.
There's a direct line down from there to the top of Raise Beck overlooking the west end of Grizedale tarn, often used by walkers and runners. It's not much of a path as such though - just steep tussocky grass straight down the hillside and following an old tumbledown wall lower down.
Posted : 25/09/2012 4:50 pm
 wl
Elliptic - thanks very much for this - that might well be the one. I'll forward a link to my friend for confirmation. Sounds as though it might not be such a smart descent - I was hoping for an actual trail really, albeit a challenging one. Ta anyway - you've possibly just saved me a fruitless slog!
Posted : 25/09/2012 4:57 pm
No probs. By the way the descent that agentd mentioned (to the phone box and the 181m spot height on the 1:25000) is the Wythburn path, which is pretty steep and rocky - probably most of it is rideable if you're good enough (I've never tried) but definitely not an easy option to the Dollywagon descent.
Oh and the "push" up Raise Beck from Dunmail is mostly a carry. I've been up there more times than I can remember on foot, but only once with the bike 😉
Posted : 25/09/2012 5:19 pm
 wl
Thanks again, elliptic. Wythburn is the one whose name I'd forgotten - I've done it and it's great if you like that sort of thing (which I do). It's over pretty quickly though. Steep, with awkwardly placed drainage ditches, then there's an obvious left-hander (which you can slightly cut using a chute) after which it flattens out before entering the woods. Carried up to Grizedale a few times too, but that descent to Patterdale/Glenridding is always worth the effort.
Posted : 25/09/2012 5:27 pm
Yep, the Grizedale descent is great value though it's ages since I've been down it actually. This was looking back at sunset on New Years Day 2009... the little white sliver in the sky is the new moon:
Posted : 25/09/2012 5:44 pm
 wl
Nicely shot.
Posted : 25/09/2012 5:48 pm
Yes the other way, ie left at sticks...fast grassy first bit into a tech gulley section then some switchbacks to the valley floor. 8)
Posted : 25/09/2012 6:11 pm
We're heading up there tomorrow via tongue gyll 🙂
Posted : 25/09/2012 6:16 pm
 wl
Cheers. Done Sticks that way a long time ago - might be time for a revisit. This time around we're settling for Wythburn followed by a bit of tarmac and carrying to finish with Grizedale Tarn to Patterdale. Interested in Red Pike (overlooking Buttermere) if anyone knows anything good here. And Ullock Pike - anyone got any tips? Ta.
Posted : 26/09/2012 9:20 am
Hi Will
Ullock Pike - there are two descents off the summit down the scree. Both are top fun. The descent itself is easy to follow. I usually then head along tyhe Allerdakle Ramble to the saddle at Carl Side for the steeeeeeep grassy path descent to the village below. Marvellous! 😀
Posted : 26/09/2012 9:52 am
 wl
Nice one, Sanny - thanks for this. I've added it to my ever-expanding list!
Posted : 26/09/2012 9:54 am
 wl
Cheers, Ben. I'm crap with maps - is this different from the one I call Wythburn? The one I know starts a bit dull on a gravel track, then it gets rougher and pretty steep before flattening out a bit into singletrack which then leads through a gate I think, ending with a fast, rough descent through woods to a car park next to Thirlmere. Ta.
Posted : 26/09/2012 10:37 am
Ah. It is the one you call Wythburn. Sorry!
Posted : 26/09/2012 10:42 am
 wl
No worries, Ben - thanks anyway. Top descent that, although it's a particularly rapid loss of height and all over much too quickly as a result, of course.
Posted : 26/09/2012 10:47 am
Red Pike isn't that much fun in itself. Kinda featureless scramble/scree-fest iirc. Sometimes worth doing as part of a mahoosive day involving Black Sail, Sty Head etc.
The Fleetwith BW from Honister Slate Mines down to Buttermere is apparently worth doing.
[url= http://www.streetmap.co.uk/map.srf?x=320860&y=513495&z=120&sv=320860,513495&st=4&ar=y&mapp=map.srf&searchp=ids.srf&dn=639&ax=320860&ay=513495&lm=0 ]Fleetwith map link[/url]
Posted : 26/09/2012 10:49 am
 wl
PS - nice pics. Ta for whetting my appetite - I'll be there again before long.
 wl
If it's the one I think it is (and I'm pretty certain it is) that Fleetwith dh is one of the best in the UK - a total cracker, and a big challenge to genuinely nail it all in one go (there's a tree near the bottom that's tricky to get around). Surprised you've not ridden it already, Ben. Check it out. It can be incorporated into the 4 passes ride/carry if you park at Seathwaite.
Posted : 26/09/2012 10:57 am
Yeah. It's just one that's escaped my notice before now. Have ridden past it a few times too and done the whole of the road Honister Pass instead. D'oh!
Posted : 26/09/2012 11:01 am
p.s. are you Will from Hebden? i've just put 2 and 2 together! 🙂
Posted : 26/09/2012 11:02 am
Aye, my mate Pete raves about Fleetwith! Given your Verbier honed skills Will, I reckon it's a pretty serious challenge to nail in a oney!
Posted : 26/09/2012 11:30 am
It is the same Will then. Hello! 🙂
Posted : 26/09/2012 12:16 pm
 wl
Ayup, Ben - yes, it's me! I'm always on the lookout for new trails, so I've taken to picking brains on here. Hope you're well.
Sanny - you should check Fleetwith too. It's not so much crazy steep like Rossett, but it's a very long rock garden, full of rubble and with some natural steppy bits and a couple of tight squeezes. Needs a bit of momentum and commitment in places, and it's quite exhausting too, so a breather is good (for me, at least - that's why I'll probably never manage it all in one go). Mint descent all round.
Posted : 26/09/2012 12:43 pm
Sounds ace in a Mr Bojangles kind of way. I'll keep it for when my new Turner arrives to replace the one I've cracked though on second thoughts, the cracked one might be the one to use as it's still rideable. 😀
Posted : 26/09/2012 12:57 pm
 wl
Fleetwith might just finish off a cracked Turner! Anyway, once you've done it, let me know what you think. Have fun.
Posted : 26/09/2012 1:05 pm
The descent off St. Sunday Crag to Patterdale is definitely one to add to your list; plenty steep and technical.
Be good to meet up again for a Hebbers ride (if you all haven't been washed away!)
[PS: I'm James - red t-shirt in the vid - rode with you and 'Orange' Dan a few times]
Posted : 26/09/2012 4:38 pm
@ben - nice photo's
@freeride - I decided to take a look at Striding Edge a couple of weeks ago, did so, turned round and had lunch at Red Tarn instead ! It took my mate 45 mins to scramble to summit from where he promptly went down the wrong side as zero viz and didn't return.
[url= http://www.mountainrescue.org.uk/news/2012_036 ]Oooppss[/url]
I never made the summit so planning to go back on the bike
Posted : 26/09/2012 5:21 pm
just been up there today via tongue ghyll and dollywaggon pike cracking ride/push/carry 😉
video of descent from helvellyn here
Posted : 26/09/2012 8:26 pm
Fleetwith is great, loose as a goose...not as tech as Rosset though 😯
4 passes is the best day out in the country IMO...
Must do Sannys Classic over the western fells soon..
Also St Sunday, that looks ace.
Jamba, that would have embarassing if they had gone up the hill looking! and his safely tucked up in the pub!
Posted : 26/09/2012 8:45 pm
Rossit is good but let down by the bottom half! Red pike t'other way round is good so is nanbield t'other way round!
Posted : 26/09/2012 9:22 pm
 wl
pussywillow - what's a good route incorporating Red Pike then? Ta.
Posted : 27/09/2012 8:29 am
 wl
Ayup, James (Newton?) - yep, be great to hook up with you and Dan again soon, over in Hebden or elsewhere. I'm in touch with Dan fairly regularly so will get something sorted. Saw your vid a while back - St Sunday's on my list since then. Hope you're well.
Posted : 27/09/2012 8:33 am
hi guys,
Fleetwith pike was mostly a walker for me on my 100mm hardtail last winter with a touring rucksack on... I would like to try it again on my 5 spot - the section between dubs hut and before the trail veers right was ridiculous in the wet - the rest was quite sweet... still i reckon its a serious undertaking with a lot of scope for pain...
last weekend I rode greenup edge / lining crag on my flux - that was a challenge.... also did the blea tarn to watendlath trail - that was nice...
I still have rossett pike burned into my memory as ' never again ' = I love nan bield and helvellyn - still got to do red pike by bike though...
paul
Posted : 28/09/2012 6:49 pm
