Help XT M786 medium...
Help XT M786 medium cage mech 11-46 range?
[#13046777]
Has anyone got an XT M786 medium cage to work with a 10 speed 11-46t cassette or do I have to surrender to a long cage? Trying to do a parts bin build on the cheap ;o)  Experience preferred as Shimano are always a touch conservative with they’re tolerances.
Thanks
Tim
Posted : 18/11/2023 11:23 am
The cage length has no bearing on max low sprocket size, only the max capacity. Both of those mechs are rated for a 36t low sprocket. IME the older Shimano mechs really don't play very nicely with large rear cogs, one of the current 10spd Deore mechs will work so much better.
Posted : 18/11/2023 11:30 am
Not that helpful to you but I’ve got a medium cage M786 with one up rad cage fitted and it works fine.
Posted : 18/11/2023 11:44 am
 Andy
Run a M786 medium cage mech with 11-40 on one bike and works fine. Dont think it will cope with the 46T without one of the widgets to extend range
As SDB says I would grab one of the cheap M5100 or M5120s that are knocking about and use that.
Posted : 18/11/2023 12:06 pm
The bike my lad is using has an older 9 speed medium cage XT mech running 11-42 using a small hanger extender (road link type) no problem. To go bigger might need a longer extender (goat link type).
If you can compromise to 42 tooth and/or use a hanger extension it will probably work.
Posted : 18/11/2023 12:43 pm
Thanks all
Posted : 18/11/2023 4:06 pm
