Help with sag on 20...
[Closed] Help with sag on 2018 fox dpx2
[#10569481]
Hi guys I'm trying to set sag on a new fox dpx2 on an intense bike. The shock is 216x63 so at approx 30% sag I should be getting roughly 20mm travel at body weight at approx 205 lbs air pressure. Trouble is I'm having to pump the shock up to close to 300 lbs to achieve 22mm, any ideas? I've heard they require more air pressure than fox state but has anyone else had to put so much more in? Thanks I think I've sorted it. Natural riding position is NOT sitting down!
Posted : 06/04/2019 8:36 pm
Have you got the blue lever in the open position?
Posted : 06/04/2019 9:15 pm
Yes you should be standing up in the 'attack' position.
Posted : 06/04/2019 9:18 pm
