Hi all
Does anyone know what make of hub i have
The hub looks identical to a hope but isnt badged up, the inner axle running through the hub screws together I've had it to a local shop but can't shed any light as to the make of it, I tried to remove what I thought were 9mm QR adaptors but had to butcher it to remove it
Any help much appreciated
It's a bulb (not a light bulb you divot)
Bulbs still say hope on them. Front or rear?
I was thinking BULB. They used to have stickers on them rather then being etched. Easier to remove.
My rear Bulb is etched rather than a sticker.
If the "Axle" screws together it not a bulb they use a one piece axle
The front has a two part screw together axle. Later ones were etched, earlier ones has stickers.
wot onzadog said about the axle
(shame you've busted it, they're saleable)
6 bolt or bolt on spider? Im also going really old bulb
Should have noted the hub is the front
It's 6 bolt
The bulb front hub qr adapters screw together, you put an Allen key in each end and unscrew it.
Bulb front hub QR's screw together. Normally use 2 5mm Allen keys to unscrew. If you look in where the bearings are you should see a cirlip groove for the 20mm adaptors.
If i email someone some pics of them could the load them up on here for me please? Im useless URL etc where's the window to view the oil level and I'm ok!
Problem over its a bulb hub thanks for all your help cheers
Earlier hope hubs weren't etched they had stickers. If the sticker comes off.....
