Help wanted - brake...
[Closed] Help wanted - brake disk adaptors
[#333937]
Hi all, I'm struggling to work out which adaptor i need for my brakes. It is to mount an IS caliper to a rear IS mount and run a 160mm disk.
Any help wold be gratefully received!
Posted : 23/02/2009 9:28 pm
Shouldn't need an adaptor if it is IS calliper
Posted : 23/02/2009 9:29 pm
Yeah, what he said. Unless your caliper is designed for a bigger rotor.
Pics would help.
Posted : 23/02/2009 9:31 pm
Ahh, my mistake, i thought it was 140mm rear brakes that didn't need mounts.
Posted : 23/02/2009 9:36 pm
Hmmm I think you do need an adaptor. Rear IS calipers are usually for a 140mm disc and no adaptor. To go 160mm at the back you usually need a + 20m adaptor.
Posted : 23/02/2009 10:06 pm
Depends on what brake you've got, IS used to use bespoke calipers for different size discs, ie Hope mono no.3 for 160mm rear/180mm front.
Posted : 23/02/2009 11:53 pm
The brake is a standard Deore IS mount brake if that makes any difference?
Posted : 24/02/2009 9:01 am
No adaptor needed for that.
Posted : 24/02/2009 9:17 am
