I have a flat workbench and a vise.
I would like to know what files I should buy to start practising.
I will be building with steel so specifics would be great.
I don't wanna tool up with machinery just yet.
Please advise.
8", 10" and 12" half-round second cut.
something you can use to make accurate mitre cuts in various tube thicknesses.
You would find a hacksaw, with a 32tpi blade, handy as well.
you are richard sachs and i claim my voucher
No, he has a Bikemachinery frame fixture and I do not.
Having enough of the right tools does help,
http://antbikemike.wordpress.com/frame-building-classes/six-week-frame-business-course/
.....and being able to braze or weld is a big help as well.
http://bohemianbicyclesfaq.wordpress.com/
lots of people have opinions on frame fixtures
https://www.google.co.uk/search?hl=en&q=bicycle%20framebuilding%20jigs&um=1&ie=UTF-8&sa=N&tab=wi&biw=1024&bih=579&sei=reeRUYbqPNCQ7AaNvYCQBQ&tbm=isch
we have our own opinion on frame fixtures
http://www.flickr.com/photos/compositepro/
if your in wakefield drive down to junction 34 and bob in and say hi
Andrew denham of the bicycle academy does welding courses and building courses
Some cast iron vee blocks. (shop carefully as some of the ebay ones turn out to be tiny)
Clamp blocks to hold tubes in the vice.
Angle finder / protractor
http://www.stakesys.co.uk/product/angle_finder_3/
Dial angle gauge (dunno why but I tend to use this more than my digital one).
http://www.whiterosetools.com/Silverline-250471
Tube notcher and a pile of holesaws (when you get bored of filing)
http://www.stakesys.co.uk/product/sta155_hole_saw_tube_notcher/
Files - anything you can find. Ideally a small and big one in each of flat, half round and round. You are only filing stuff a few mm thick so actual grades not especially important provided they aren't super coarse.
A couple of rolls of emery cloth (coarse and medium).
Word of caution - be very careful what you are starting 🙂 It won't stop and the pile of tubes, tools and other stuff keeps on growing....
[url= http://www.instructables.com/id/A-simple-bicycle-frame-jig/ ]Instructables Bike frame jig[/url]
Tube blocks - you can make your own, but the Paragon ones are cheap and good. Bastard cut files are good for roughing out. I also used to use a hand nibbler quite a lot for mitring, to get the shape roughly then file to fit. A fork cutting guide is also handy for cutting tubing square (you can use a tube cutter, but the FCG works on oval things like chainstays).
Really, though, all you [u]need[/u] is a couple of files and a hacksaw. Everything else just makes life faster and easier.
... and a bunch of knowledge, aptitude and practice.
I dread to think what I'd end up with if I tried building a frame with the files and hacksaw sitting ready in my shed 😳
Well, yes - learning the principles you can do in a weekend, getting good at it takes a while longer.
