Help to source 0W-3...
[Closed] Help to source 0W-30 Rockshox Oil
 scz4
[#9388431]
Going to perform a lower service on my 2016 Pike, so looking to purchase a 120ml bottle of 0-30 oil (I only need 20ml) but it would appear to be impossible to source.
Well that's not true, can easily source 1 litre at £25, but that's 50 oil changes worth, so a little over kill 🙂
G
Posted : 18/06/2017 10:42 pm
TFTuned have it but it's nearly a tenner for 120ml!!!
Bloody hell!
**EDIT No they don't, my mistake.**
Posted : 18/06/2017 10:46 pm
Just use some car engine oil of a similar weight. It's only there to provide a bit of lube, it doesn't do any damping work so it's not too critical. I've used some 5-40w in the bottom of my Pikes with no issues...
Posted : 18/06/2017 10:54 pm
 scz4
Good shout on tftuned though, they do this http://www.tftuned.com/tf-tuned-lower-lube-kit/p554
Posted : 18/06/2017 10:59 pm
Any bike shop with a Zyro/fisher acccount
Posted : 18/06/2017 11:01 pm
https://www.24mx.co.uk/maxima-maxum4-ultra-ester-100-synthetic-1l-1
£20 for 1L.... but still a touch more than you need 🙂 As above just use some fully sythetic engine oil. Weight is fairly unimportant.
Posted : 19/06/2017 7:24 am
I always get fork oil from motorcycle shops. Much cheaper, you get the choice of weights and you know it won't cause the seals any problems.
Posted : 19/06/2017 7:29 am
I was in the same boat as you. In the end I got 1L of motocross racing fork oil as it was only a few pounds more than a 120ml of the Rockshock stuff. I just went for 2.5wt - will make naff all difference compared to 0w as you need so little of it anyway.
Posted : 19/06/2017 8:48 am
 poah
Amazon
Posted : 19/06/2017 2:57 pm
got mine from bike-discount
Posted : 19/06/2017 3:49 pm
What you put in the damper is different than what you put in the lowers, but TBH at only £13 for a L of the actual 3W oil you'd probably not skimp surely? £7/8/900 worth of fork but you'd not pay £13 for the right damper oil 😉
Posted : 19/06/2017 4:16 pm
 poah
Drop me a message to my email in profile, I'm sure I've got a couple of 120ml bottles at home left over from a job lot I sold a while ago.
Posted : 19/06/2017 5:19 pm
 scz4
^ Thanks, I've dropped you a mail.
Posted : 20/06/2017 1:25 pm
