I'm thinking of changing my sick fox triad rear shock off a 2011 Camber expert for genuin fox, broken second time in two years. but unsure how measure the stroke, the lenth is eye to eye. anyone help please
51mm stroke from the look of it.
Surely you just let all the air out and compress it to the stop?
I make it 200mm lenght and 55mm stroke if iv'e measured it rite. I can find one but it's only 51 stroke, thanks so far.
A 200x51 and a 200x55 are the same length, (200mm 😀 ) the 51mm stroke version has a limiter on the shaft (inside, not visible) to reduce the stroke, according to the chart up there ^^^ yours is a 51mm stroke, if you get a 55mm one it will compress too much and possibly damage your frame..
