I've just bought some second hand Hope Mono Minis (pre 2007 with IS mounts) to put onto my 2007 Fox Float RLs which also have IS mounts. Problem is, I can't work out what mounts I need. Just about all the ones I can find on the 'net are Post to IS or IS to Post, not IS to IS. I'm looking to run 160mm max rotors.
Am I being stupid? What mounts do I need? Do I even need mounts?!
Also, there seems to be an absolute stack of rotors out there - which ones would work best with Mono Minis?
Thanks.
is calliper to is fork / frame no mounts needed - you need the correct size disc for the caliper you have - the caliper has a number on it and that number corresponds to the disc size. the number is stamped on the lower mount lug IIRC
Aha, progress! There's a 3 stamped onto the lower mount of the calliper. So that's a 180 front and 160 rear.
THANK YOU THANK YOU THANK YOU!!
Hope still make a plus 20 and plus 40 mm is to is mount but jut try fittin them and see if it works with the rotors you have.
Think your old minis would use either 160 or 185 rotors but been a while since I had any
Hope are stunning with there customer service of you ring them direct
