Help setting up mar...
[Closed] Help setting up marzocchi 66s
[#1387628]
I recently bough a speccy demo 7 off pinkbike, but can't for the life of me work out how to set the forks up. The manual is pathetic. They have a scraeder vlve on the top of each leg, which as far as I can understand is to do with preload? However if I pump them up as it seems to say in the manual ("spring preload with air") there is a table which suggests 40psi for my weght category. However, 40psi and the forks actually stop compressing completely. What's going on at all??
Thanks...
Posted : 06/03/2010 2:02 pm
 IA
Which flavour 66s would help folk help you...
Year, and model. Failing that, pictures, and pics of the top and bottoms of each fork leg.
Posted : 06/03/2010 2:12 pm
(edit: posted at same time as IA)
Which model 66?
Posted : 06/03/2010 2:13 pm
Sorry, 2008 RCV
Posted : 06/03/2010 2:28 pm
don't worry, it's only 15psi max I've worked it out now (I think)
Posted : 06/03/2010 2:45 pm
