Hi all, just about to replace the SPD cleats on my Sidi Doms and they are stuck solid and the screws look rounded too.
How do I get them out?
Posted : 08/11/2010 8:22 pm
2mm drill bit through the centre followed by a 4mm, job done!
Posted : 08/11/2010 8:24 pm
What popo said. Don't be shy with them either.
Posted : 08/11/2010 8:26 pm
Dremel a slot across the top then use an impact driver with a flat head screwdriver bit.
Sorted
Posted : 08/11/2010 8:27 pm
I just attacked mine with a 5mm drill, then pulled at the spd which snapped the leftover countersunk bits off and unscrewed the remainder with pliers.
Posted : 08/11/2010 8:35 pm
Thanks to all
I'll get cracking
Posted : 08/11/2010 9:07 pm
