Help removing Sram ...
[Closed] Help removing Sram DB5 brake from bike
[#9562811]
Hi this may be a stupid question but some times they need to be asked. Removing my DB5 brakes that is internally routed through the swing arm on my five.
When i remove the hose from the lever i cant get it through the hole on the swingarm because the cover wont come off because it wont move over the little silver NUT/or olive.
Can i remove the hose from the caliper end rather than the lever end? Their seems to be a 8 mm nut on the caliper end just like on the lever.
Thanks all.
Posted : 21/09/2017 6:28 pm
The hose will unscrew from either end but the compression nut ( 8mm spanner thing ) may not go through the swing arm ?
But never tried it with a orange 5 personally
If it won't go through you will need to cut one end of the pipe off as the olive and barb and not always reuseable
Have a look on you tube for hose fitting instructions and it should become clear
Posted : 21/09/2017 7:07 pm
Thanks i done it,managed to pull the olive off.
Posted : 21/09/2017 10:02 pm
