Hi folks
I have a wobbly rear wheel on my road bike. It's not buckled but if I tighten up the QR and release the brake I can grab the wheel and push and pull it towards either chainstay. Additionally - when I tighten the QR the wheel tends to get pushed to one side meaning the brake blocks rub. Any ideas?
TS
Hub bearings loose / worn?
What wheel?
It's an Alex Rims wheel ( I think ) - no idea about the hub at the mo.
Guessing it'll have cup & cone hub - have a look on the park tools site to see how to adjust
Sounds like either a loose axle or worn bearings to me.
Take the wheel out of the bike and holding each end of the axle give it a shake. If the axle is loose then you'll feel it quite readily. You can nip up the nuts on either end of the axle to account for bearing wear.
