Help please!!! Gear...
[Closed] Help please!!! Gear problems
[#7003602]
Right I'll try and be as brief as can, ride a specialise enduro 2015, half a year through and changed the drive train, new chain sprocket rear mech and hanger plus front chainring , upped it to a 34t from 32t. Now, the problems....
Few weeks ago, riding up peaks, on fast rough descents in the lowest gear And pedaling hard (so lots of tension on everything) chain won't stay in gear, jumps around and means I can't pedal. The problem been getting slowly worse and now seems to do it wherever I am, as soon as power is needed,nove just snapped my 3rd chain 🙁 and before people suggest the obvious I'm using a good quality £50 kmc chain, swapped to sram and snapped that tonight 🙁 . Totally at wits end, and my local shop can't find any fault, and the dealer I brought it from is reluctant to help. Bikes under a year old....
Posted : 16/04/2015 8:10 pm
Sounds as though the rear mech isn't quite indexed spot on. Check your b tension too
Posted : 16/04/2015 8:12 pm
