Help please
[Closed] Help please
[#4500424]
Bought a set of hope straight pull wheels. However the rear was a qr, but mine is a 142 12. Bought a kit on CRC which is the pro 2 rear x12 thro kit. But I need to remove the axle from the hub and cannot work out how to do it. I have looked on hopes site and nothing there.
End caps and free hub are off, but the new end caps received do not fit on the current axle, so a bit worried I have spent £20 quid unnecessarily.
Please help,me!
Posted : 27/10/2012 11:06 am
The last hope hub I took apart was a bulb. To remove the axle you had to hit it hard (from the drive side I think) with a mallet, or hammer and block of wood.
It'll be the same for the pro2 aswell
This pushes the bearing out, you'll need something to hammer it back in with. A socket bit the right diameter works well.
Posted : 27/10/2012 12:02 pm
Have a look on you tube a hope have put a video up on how to strip the pro 2
Posted : 27/10/2012 1:59 pm
Got the new axle in and it's too narrow for the freehub body.
So loads of play in the freehub body when it's attached.
Any ideas.
Posted : 27/10/2012 4:10 pm
Sound like you may have got a kit for the pro 2 rather than the pro 2 evo which I think is the one use in the wheels now
And one other thing to check older 12 through axle and 142 is not the same thing
But it's been a while since I've done a conversion. There used to be a technical bit on the hope site with all the info on
Looks like all you need to go from qr to 142+ is two new end caps
To be sure check the list here and look up what you need
http://www.hopetech.com/page.aspx?itemID=SPG280
Posted : 27/10/2012 5:08 pm
