Help out a tubeless...
[Closed] Help out a tubeless virgin?
[#4580698]
Hello all
I have some UST rims with non UST tyres on them, while the're holding air just now, I can nearly burp them by hand at 25psi if I squeeze the sidewall air does escape but the stans fluid stops it eventually
I'm guessing I need a rim strip in there (there isn't one just now) will any rim strip do that is the width of the rim? or should I get the Stans yellow tape? (is this stuff sticky for covering up the rim holes?)
Posted : 21/11/2012 9:46 pm
What rim? What tyre?
Posted : 21/11/2012 9:52 pm
Mavic Crossmax SX and Maxxis Ardents (the EXO walled ones)
Posted : 21/11/2012 10:01 pm
 XXX
Did they 'ping' at least twice when you put air in? Sounds like they are not seated. You don't need the strips
Posted : 21/11/2012 11:03 pm
Not really there was a bit of ping but I was expecting more, and I pumped up to 50psi. If I let the tyres down they still say in place but leak air under 20 psi
Posted : 21/11/2012 11:12 pm
 XXX
Keep pumping, sometimes it can take up to 80psi before they go.
Posted : 22/11/2012 12:28 am
