help on on one ti45...
[Closed] help on on one ti456 set up/spec
[#1049070]
hi all, just got myself ti 456 and would like advice on the build.Whats the best forks? do i need u turn/talas or just set height? if so whats the best height. Whats the lightest wheels that would suit it. any other info would be great
cheers
Rich
Posted : 17/11/2009 6:24 pm
carbon rigid forks
or
160mm coil sprung
Posted : 17/11/2009 6:28 pm
Running non adjust 2010 maxle revelations on the front of my Ti 456. Cost me £350. Might have considered U Turn but they are a hell of a lot more expensive (think they may only be available with mission control damping). The bike rides nicely so far and it looks bloody brilliant.
Posted : 17/11/2009 7:13 pm
I used to run 140mm Vanillas on mine - never felt the need to reduce the travel
Posted : 17/11/2009 7:15 pm
140mm + travel with a bolt through axle.
Bigger is better in the case of the Ti456 IME.
Posted : 17/11/2009 7:35 pm
140mm u-turn revs on mine - they never need to be wound in though, even when climbing 🙂
Posted : 17/11/2009 7:40 pm
 br
Mine is going to inherit the setup from my current steel 456:
Either 120mm Reba maxle or Fox 36 talas 150mm (depending on route), Hope Hoops cw XM819's running tubeless, Avid Juicy carbons with full ti bolts, XTR crankset/mechs, Thompson stem, Sunline V2 bars (although want some lighter ones) and I-Beam seat and post.
If I had to buy a fork, either a Fox 32 140/150mm talas or the new RS Revelation U-Turn and new wheels would be Hope Hoops with Stans rims.
Posted : 17/11/2009 7:47 pm
Mine is set up with air 454 pikes, hope hoops with DT5.1, xt drive train (26/36/bash). xt brakes, thomson stem & post, Easton monkeylight bars. Fairly light for a bike that will take a real beating. Pikes have uturn but hardly ever use it.
Posted : 17/11/2009 10:45 pm
Pikes with U-Turn that never gets used here too. Thinking of swapping mine out for something else - want to buy them (push tuned too)??
Posted : 17/11/2009 10:51 pm
