Help needed with ho...
[Closed] Help needed with hope hub
[#2052347]
I've bought a set of second hand wheels with hope hubs, i think they are hope bulb? and I'm trying to convert the front into QR. I've bought(from crc) for hope pro 2 and when placed it makes the wheel too wide for forks.
any ideas?
Posted : 03/10/2010 9:00 pm
is it a hope pro 2 hub? If it is not you have the wrong part. Hope hubs say what they are on the hub under the logo Perhaps you have wrong size fitment? Is it a bulb/xc hub? Hope have Hope etched on them why are you unsure if it is a hope?
Posted : 03/10/2010 10:47 pm
I always thought they were the same but according to Hope...
Pro2 QR adapter is [url= http://www.hopegb.com/voir_pro2sp3.html ]HUB419[/url].
Bulb QR adapter is [url= http://www.hopegb.com/voir_PBUAV.html ]HUB415[/url].
Posted : 03/10/2010 10:51 pm
Just to be sure, measure the spoke circle diameter on the non-brake flange-Pro 11 is 54mm, Bulb is 47mm.If you have a Bulb then the converters you have won't work, the correct ones for a Bulb are offset, and screw together to form an axle inside the hub.
Posted : 03/10/2010 10:55 pm
