A few rides back my seat came lose and I tightened the clamp bolts out on the trail (Afan). Unfortunately I overdid it and snapped one and had an uncomfortable ride back. Next day I managed to find a similar bolt but because I'd lost the little square washer I had to bodge it with a bit of rubber cut from a tube. That did the trick temporarily but it does still keep coming lose and I need a more permanent solution.
To make matters worse the upper and lower parts of the clamp are now worn and no amount of clamping seems to hold it for long.
The lower part is integral to the post, as KS Cruxi dropper and I can't see a way of removing it.
I've been trying to source a new bolt and washer and possibly upper part of the clamp but not had a lot of luck. Does anybody have any of these components in their bin? See pics.
