Help me put my whee...
[Closed] Help me put my wheel on!
[#5915421]
So.. I have a Cannondale Prophet with the bolt through 12mm rear axel. It came with a wheel that fits it fine, but I want to run another wheel with a Hope hub, (not sure exactly which one, its three or four years old). Anyone know what I need to buy to made it work?
Posted : 03/02/2014 12:25 am
Which hope hub? What axle is already in the hub?
Posted : 03/02/2014 12:38 am
The Hope hub should have a model name etched into it. Pro II or XC probably. Is the frame 135x12 or 150x12? If its 150 then you need a new hub, likewise if its an XC then you need a new hub aswell I think. if its 135mm you can possibly get converters (if its a pro II).
Posted : 03/02/2014 12:40 am
If it's a 135mm Pro 2, you need a replacement axle and end caps. Which coincidentally, I have some of to sell 😉
If it's an XC or Bulb I don't know. If it's a 150mm Pro 2, it's not happening.
Posted : 03/02/2014 12:46 am
I can't see any etching on it. Where am I looking? Here's a pic. It has a QR axel in it now. It's a 135 for sure. [img] [/img]
Posted : 03/02/2014 2:15 pm
As said above, you need a different axle and cups .... which I happen to have a spare set of for 135x12.... and I happen to be based in Southville, Bristol.
Yours for £10? You will have to collect though as I am sprog duty today!
Email in profile if interested.
Posted : 03/02/2014 2:43 pm
Sounds good Sammy. I'll email you...
Posted : 03/02/2014 4:07 pm
