Are they cerit , I had some that looked like that came stock on an anthem and after much searching that's what they were iirc
thanks, will check them out.
Yep they do look like Cerit hubs.
http://www.dtswiss.com/getdoc/041ab297-17cc-427a-9bdc-277c4778733a/Datasheet.aspx
This should be the data sheet for it. They dropped Cerit and went for the 370.
Service manual here mate, mine were stock on an 2007 anthem
[url= http://www.birota.ru/manuals/dtswiss/onicundceritrev2003-2004.pdf ]manual[/url]
Great, thanks.
So they are Cerit hubs branded DT for oem on bikes?
Seem like ok hubs.
oh i get it, cerit is just a model name
Yeah they seemed to stick ones called cerit or onyx on stock bikes , the manual will cover all you need. Iirc they were meant to be around the same standard as xt, I never had a problem with them
