Help me go tubeless...
[Closed] Help me go tubeless!
[#5394764]
I have some wheels I am interested in making tubeless if that is possible.
Front: Mavic XM719 with folding Conti Rubber Queen BC 2.2
Rear: Mavic XC317 with folding Maxxis Crossmark 2.25
I don’t mind spending a bit but I do want them to work reliably, I don’t like the look of the ghetto method as it seems to involve a layer of innertube between the tyre and rim interface which isn’t there at the moment so I am thinking rim strips are the best way.
Can anyone recommend which ones to go for and in which sizes and what other bits I need (I think it is just latex solution) or do I need new tyres immediately?
I realise the luxury option is a new set of Hope Hoops with Flow rims but I would like to give it a go this way if I can to see if I like the benefits (or firstly if I can tell the difference).
Posted : 05/08/2013 3:58 pm
Simple then. Sell those wheels and buy some with UST rims and some UST tyres. Sorted. No other stuff required (sealant optional).
Posted : 05/08/2013 4:12 pm
By a bit I meant like up to the value of tubelss bits and bobs and if needs must new tyres, not a set of new wheels.
At the minute I want to give it a go as it were but full UST is to spendy for me. If I move on from this it will be to Flows and tubeless ready tyres.
Posted : 05/08/2013 4:21 pm
I've got away with using roval/stans type tape, a superstar valve and then some 99p double sided foam tape (with the backing left on) to fill in the central gutter on awkward rims.
Posted : 05/08/2013 4:34 pm
you can use quite a few different options for the tape.
some riders use gorrilla tape, some use installation tape. i used superstars rim tape and i also got the valves off superstar as they were the cheapest i found. buy a bottle of stans and away you go. those starter kits are exspensive. alot cheaper to buy the items separate.
Thanks Twang,
That looks good, two sizes of strip 17-19mm and 19-25mm which would be right for my rims?
I thought the 7[b]19[/b] of the rim was the measurement of the width but having just checked the Mavic website this doesn't seem to follow exactly!
Posted : 05/08/2013 4:38 pm
Is this essentially gaffer tape or something different - heard this mentioned when tublessing Rabbit Hole rims...
Posted : 05/08/2013 4:58 pm
I thought the 719 of the rim was the measurement of the width
Yep 19mm internal so the 17mm - 19mm should be ok - especially as you dont want the ghetto overhang 😉
Posted : 05/08/2013 5:35 pm
Just bought those two twang linked as well.
Thanks.
Now off to tyre browse....
Posted : 05/08/2013 6:00 pm
I did my first tubeless conversion last week. DT Swiss rims with Specialized tyres, one 2bliss ready, the other not. One needed a couple of patches to cuts. I used a couple of turns of electrical tape on the rims, and valves cut out of old tubes. The only cost was a bottle of Stan's fluid. With the help of some soapy water both tyres inflated with a track pump, and have not gone down yet.
It's hard to explain just how smug you feel the first time you get a tyre to inflate without a tube, and i like the extra grip that low pressures give you.
My advice - get some fluid and give it a go.
Posted : 05/08/2013 8:51 pm
Exactly the same as Skeetsgb and I have Mavic xm719's.
Needed to get local bike shop to use the compressor to get them to inflate.
Posted : 05/08/2013 9:08 pm
You don't need to spend much to go tubeless hs125 has got it right. Although I would actually buy the valves. Insulation tape 3 times round and a bit of stan's in there. Fairy liquid and track pump- boombadabing.
Posted : 05/08/2013 9:55 pm
Just a thought (as I have no idea) but will those tyres go up tubeless?
Posted : 05/08/2013 9:58 pm
Get proper tubless tyres. Big difference to ghettoed tubed tyres.
Posted : 05/08/2013 11:43 pm
