Components wise here is what i have got!
Stans 355 rims on pro2s
Fox talas 100-140mm
Carbon FSA risers
90mm Easton ea70 stem
Avid Elixir brakes
x9 mechs and shifters
slx chainset
Gobi saddle
All "lightish" stuff - what hardtail frame would they compliment? Certainly not 456 kit imo
What you gonna use it for?
Sounds like a nice set of components for a 456 or a Soul.
Yeh what you want it for? XC, DH, All rounder?
Chameleon? bit rigid for all day riding though apparently or maybe a P7?
Cotic Soul? Blue Pig? Mmmbop? Good with that fork (perfect in fact). On-One Scandal still amazes me every time I drag it off the missus.
Dialled PA or a soul, have had both (still have the PA) both would work sweetly dressed in that kit.
Failing that a nice carbon frame like a Scott Scale if you want a more xc ish lightweight ride......
I have just put similarly light kit on a van Nicholas mamtor ti.
Chumba HX1
XC predominantly (peaks/trail centres)- clumsy rider tho!! 82Kg in weight so not a heifer!!
Budget?
Lots of options with that kit.
Forgot - joplin 30.9 seatpost 🙂
suppose my ideal bike would be a sould with a 30.9 seat tube and not a BFE as they are heavy!
Get a soul and get a different size seatpost? Seems strange picking a frame based on the seatpost size
So much choice, but I loved my Kona Explosif. Lovely frame. Good steel frames are superb.
That's good enough kit (very similar to mine) to warrant a decent, light frame.
Cove Handjob or Stiffee?
Kinesis Maxlight Pro 3?
Chameleon is 30.9
My 'for sale' Inbred 853 frame (18in) 😉
If it were me I'd be looking at a Maxlight too. I'd have thought that 100mm would be limit though.
Racey-ish HT then?
Budget not an issue?
S-works M5 HT
S-works carbon HT
Or On-One Carbon Whippet when it becomes available?
+1 for the Chumba HX1
right up there for what you want to do. a very versatile frame
more fun xc than race xc
had a Dialled PA and loved it but would want lighter than that
carbon 456?
GWT - the new 725 Prince Albert is lighter than the one you probably had (520 version), but not by much.
If you want something considerably lighter, then you'll probably have to go ally or Ti. Cotic is Soul is probably the lightest steel long fork frame.
Whyte 19 alloy/steel/ti, as that would be worthy of a good build and is 30.9mm I'm sure on all 19's.
Perfect Uk hardtail!
So I guess, you should make a ''umpteenth'' new thread on what metal to have in a frame 😆
'nother vote for Chameleon
How about a Decade Virsa like wot Ben has on long term?
Cotic BFe + shim
Pipedream Sirius.
