Help! Lyrik Service...
[Closed] Help! Lyrik Service!
[#3868759]
Hi all just in the process of servicing my RS Lyrik Coil U Turn With mission control.
The problem is the amount of oil the RS guide is telling me to put in the mission control side upper tube seems way out! It says to fill with 193ml of 5wt oil and there's no way that its going to fit! it just seems an over the top amount. It may be me missing something stupid but its baffled me :\
has anyone else had this problem or know the solution?
regards joe!
Posted : 13/04/2012 8:38 pm
How old is the fork? If its a 1st generation Lyrik the amount of oil in the damper was only 112ml.
Posted : 13/04/2012 8:42 pm
Yep, older models had less oil in, old service guides confirm this.
Posted : 13/04/2012 8:45 pm
i was told there where 2009 but it could be possible that they are older i shall have a look through the older manuals 🙂 thanks guys!
Posted : 13/04/2012 8:48 pm
joe the age is stamped under the crown
Posted : 13/04/2012 8:50 pm
i couldnt see the stamp ill have to go and double check but it seems they are the 2008 versions!
Posted : 13/04/2012 8:55 pm
I did my 2009 Lyriks today and put 112ml in the damper and it works a treat. The old tech manuals have the amounts, as said above. Here's a link to the 2008 one:
[url= http://www.sram.com/_media/pdf/rockshox/dealers/TM_MY08_E.pdf ]2008 Technical Manual[/url]
Posted : 13/04/2012 9:42 pm
thanks for everyones help! problem solved!
Posted : 14/04/2012 1:51 pm
