Help ID-ing a DT fr...
[Closed] Help ID-ing a DT freehub
[#10178344]
Can anyone tell me what freehub this part number is for:
1XHXAXN01074
It says 240s Shimano MTB on the bag but the standard 12mm end cap doesn't fit.
Posted : 20/08/2018 10:27 am
Yup, that's a standard, current 10-speed road/11-speed MTB ratchet freehub.
You're missing a few letters off the end though, SB would = stainless bearings, S.A. would = standard bearings.
Posted : 20/08/2018 10:47 am
Some 240 free hub bodies have a small plastic seal over the outer bearing, effectively the 'flange' on the spacer is in the freehub body, not on the end cap. If your end cap is also 'flanged' (and most are) then it won't fit.
Can you see all of the bearing face (usually a red dust seal) in the end of the freehub body (ie the bit that would face out if it were installed in the wheel), or is there a black spacer there?
Yep, can't see the bearing due to a cover/seal:
https://photos.app.goo.gl/Q3jGybZ6HUkugJda7
Posted : 20/08/2018 10:50 am
Does the spacer come out?
Posted : 20/08/2018 10:51 am
Yep, may be easiest to push the central, cylindrical spacer aside (from the back) and push the outer bearing out, which will bring the spacer with it.
Posted : 20/08/2018 10:53 am
Sorted, thank njee 🙂
Posted : 20/08/2018 11:15 am
Pleasure, flummoxed me some years ago, made worse by the fact my Bontrager wheels did need the additional spacer in the freehub!
Posted : 20/08/2018 11:22 am
