Swapping the bearings in my Hadley 20mm bolt through Hub.
2 problems:
a) I've removed the 2 lock rings and one of the inner sleeves, but can't loosen the second. Any tips?
b) I've got a technical drawing of the hub which details the bearing as 6805-2RS, and gives the dimensions as OD 35 x ID 25 x 7. But a 6805-2RS bearing has an OD 37mm. Are 6805-2RS the correct bearings?
Thanks
Posted : 07/05/2010 4:30 pm
Pointing out the obvious but can't you measure the bearings or their cavity?
Posted : 07/05/2010 5:19 pm
