Hi I cannot push the front mech cable out of the Shimano Deore shifter. I have removed the cover screw but the cable won't push out. Rear mech cable came out fine. The Deores are 2014 vintage if that makes any difference. I am not ready for 1 x just yet. Thanks.
Shifted to the lowest/first position on the shifter?
If you have a double chain set and the shifter has the little switch to change it between double and triple ?
Then that toggle needs to be set to triple to let you remove the cable
Orangeboy you are genius.thank you so much Sir. I may ride tomorrow after all.
Enjoy the sunshine. It's one of those many fun little things Shimano don't seem to anonce
Yeah I discovered this the other week as well. Sneaky devil's.
