Got a DHX Air shock I'm having trouble with.
Seems to hold air pressure okay, but it's to be leaking maybe 2cc or so of oil from the main seal onto the stanchion every time I ride it.
I ignored it for a couple of months thinking it might be just bedding in, but starting to get concerned now that it is the damper leaking oil into the air chamber or something. Amount leaking certainly hasn't slowed down! Damper does still seem to be working at the moment.
Is it even worth opening these things up to take a look or should I just send it back (or is it normal for them to lose a bit of oil every ride?)
sounds like the seals gone to me
certainly easy to replace on my float get a seal kit and a sachet of float fluid from mojo
I'm not particularly familiar with the DHX but if it's holding air the seals must surely be OK?
no one is! But yeah, that is a good point.
Is there any risk of damaging the shock when opening it up to do the air sleeve service? (Can strip air forks down no problem, but rear shocks are a mystery to me!)
Don't want to risk the shop thinking I have caused the problem 🙁
its just the same as for the float......
ignore the bit about stuckdown
and a vid
http://video.mpora.com/watch/KRTj23Tn7/
ah nice one, cheers kimbers I'll give that a bash
Just in case anyone finds this via google or STW search (unlikely 🙂 )
Had a look inside mine last night, and it seemed okay (wasn't full of damper oil or anything). Guess it really is meant to lose oil every ride... 😯
[url= http://www.foxracingshox.com/fox_tech_center/owners_manuals/07/eng/rear_shocks/dhx_air_40.htm ]link[/url]
There may be a small amount of air sleeve lubricant residue on the body. This is normal. If this residual air sleeve lubricant is not present, this is an indication that the air sleeve should be re-lubricated. Some other things to consider for all shock models:
