HELP! Formula The O...
[Closed] HELP! Formula The One brake lever blade replacement issue
[#5784624]
So, I have a pair of 2009 DH formula the ones and recently I had an off which snapped my lever blade in half. I'm half way through the dismantling process and I've got a bit stuck. I've got the snapped lever off the master cylinder main body and some of the bits dismantled, but I can't seem to figure out how to remove the adjustment screw from its housing within the blade. Help please!
For reference here is the link for the exploded view of the master cylinder:
[url= http://www.formula-italy.com/documents/829 ]master cylinder[/url]
Parts numbered 8, 17, 11, and 10 remain attached to part 4.
Part 9 came free with some screwing, but the others remain. To provide some more detail, the top of the adjust screw (part 10) is an Allen head 2.5mm and the interior of part 8 is threaded.
Posted : 18/12/2013 10:16 pm
Wot 😯 Iv'e had a Stella or two and still don't understand this. The levers are awkward to remove I have tried. If you search on MTBR all shall be revealed. Thought I could explain 🙄 beer is not my friend tonight 😳 Tried,sorry
Posted : 19/12/2013 12:04 am
Ah. that's quite different to mine. Looks like part 24 holds the adjuster onto the lever, and part 8 and 10 thread together?
Posted : 19/12/2013 12:11 am
I had a look at mine, I think you need to grip 11 and unscrew 10 from 8.
I have Lost parts 5 and 6. The only way to get new ones seems to be buy a lever blade. Would you sell yours?
Posted : 19/12/2013 12:20 am
I think I have a spare lever somewhere and maybe the rest of the brake if you are interested, will look later anyway
Posted : 19/12/2013 2:40 am
just had a look, i have the whole lever and the handlebar mount, the thread is stripped where it joins the brake hose, im not good enough to fix it
Posted : 19/12/2013 4:38 am
Lester, i have emailed you. Cheers.
Posted : 20/12/2013 10:10 pm
Stu
Messages you back[
Lester
Posted : 20/12/2013 10:32 pm
