Help - Disc brake s...
[Closed] Help - Disc brake set up !
[#3500110]
Ok, new ish to disc brakes, as only just swapped from V's. the brakes are Auriga pro
I have a few problems;
the lever pulls almost to the bars.
the lever also 'pumps' and becomes tighter as i squeeze it.
the braking power is extremely lacking
thoughts , pads knackered, air in the system, leak in the system
anyone any thoughts ?
cheers
Posted : 28/12/2011 10:14 pm
I'm no brake expert, but that sounds like air in the system.
Bleeding is the answer, but a quick fix is to ziptie the lever to the bars overnight (like holding the brake on all night), which will help temporarily.
Bleeding is not difficult, but worth getting LBS/a mate to do it for you if you're not confident. Any decent LBS will show you how, once plied with a decent coffee...
Posted : 28/12/2011 10:25 pm
Sounds like you have some air in the system. Did you shorten the cables?
Posted : 28/12/2011 10:30 pm
could be that the pads need setting; check out the last couple on mins of this video
7 mins in should help to clarify if its air in the system
Posted : 28/12/2011 10:57 pm
