Help - Cutter.com.a...
[Closed] Help - Cutter.com.au XPG part numbers
[#946383]
Anyone ordered a triple MR11 XPG from cutter yet?
Is this what I need to order - XPGMR11T ??? I can't see any explaination of the part numbers anywhere.
Do I need secific XPG optics, or will my current XRE-R2 one work?
Posted : 13/10/2009 7:24 am
Markyd yes that is the 35mm triple xpg, you will need to order the cute optic though http://www.cutter.com.au/proddetail.php?prod=cut904
Just put one in a lumi hid housing with the narrow optic and its superb, loads of throw and nice spill too!
This is the page you need to see which ones to order http://www.cutter.com.au/proddetail.php?prod=cut904
click on the box marked xpg on mcpcb and its shows whats what
Posted : 13/10/2009 7:28 am
that last link kinda666 is to the optic, any chance of postng to pukker one. I'd like to see how much they are
ta
Posted : 13/10/2009 4:08 pm
cheers I found it here as well
[url] http://www.cutter.com.au/products.php?cat=LED+Kits [/url]
i didn't realise he had updated this bit of his site.
£53 for a triple with bflex seems OK.
but £16 for a triple LED only off that link you just put up glenh.
are they really charging £37 for a bflex?
I'm sure taskled don't charge that much
Posted : 13/10/2009 4:55 pm
I'd look for a new tripple XPG to fit one of my lamps to replace the q5's.
Just can't find where they are. Would the new XPG's need more power from the driver or could I just retrofit the new led's behind the same optic?
Posted : 13/10/2009 5:37 pm
should just be able to do a straight swap mikey
Posted : 13/10/2009 7:51 pm
Bflex from taskled costs around £24 posted from usa
Posted : 13/10/2009 9:18 pm
mikey - I think you'll need a new optic too, as per the links at the top.
Posted : 13/10/2009 10:16 pm
