Help -cannot fit my...
[Closed] Help -cannot fit my tyre!
[#5064247]
Hey, I Have DT Swiss rims which came with maxxis minions. Wanting to change them to high rollers but has taken 5 hours and 6 broken/bent tyre levers to remove the minion and I'm no where near fitting the high roller! Looked on the forums and people have suggested soap and the 'correct technique' neither of which I could find a description of.... Any tips?! Extremely grateful for any help!
Posted : 13/04/2013 10:06 pm
Have you pushed the bead away from the inner walls of the rims? There's loads of videos that are available on your favourite neighbourhood video website!
Posted : 13/04/2013 10:09 pm
I think most tubeless rims have a channel down the middle, you need to try to get the tyre beads into this channel before trying to lever one part out. It's still tight but the channel just about gives enough extra room to get a bead off.
Posted : 13/04/2013 10:11 pm
Start with the bit of bead opposite the valve.
Make sure this is in the "well" of the rim.
Keep squeezing the rim into the well as you work both hands back towards the valve.
Pop the rim onto the bead at the valve, make sure the valve isn't trapped under the bead and inflate.
Posted : 13/04/2013 10:14 pm
Thanks guys, I did eventually get the minion off, it's the fitting in really struggling with!
Posted : 13/04/2013 10:15 pm
I was the same with my Rovsls and NNics- the centre channel is your friend as mentioned above!
Posted : 13/04/2013 10:24 pm
As well as the above (making sure the beads are sitting inside the central channel), I found warming the tyre slightly on an oil radiator helped.
Posted : 13/04/2013 10:35 pm
Some dt rims are a pita regardless of the proper techniques being used.
Posted : 13/04/2013 10:43 pm
One of these tools can be useful for fitting tight tyres: Simson Tyre Mate http://www.dotbike.com/p/3845
Posted : 13/04/2013 10:45 pm
