Help! - Avid Juicy ...
[Closed] Help! - Avid Juicy O-ring issue
[#2038835]
Anyone ever had to replace the O-ring fitted to the bleed port bolt on a set of Avid Juicy brakes?
I managed to pinch the ring on one of mine while bleeding the caliper and it now leaks like a b*stard.
LBS hasn't been much help but they aren't Avid specialists.
All suggestions gratefully received.
Posted : 29/09/2010 2:01 pm
Pinch the one from the bleed kit adapter until you can find a shop with an Avid spares tackle box, they've got loads in them, probably because having to bleed frequently eats them alive.
Posted : 29/09/2010 4:59 pm
