HELP - ADVENTURE BI...
[Closed] HELP - ADVENTURE BIKE GEO ADVICE
[#8180944]
hello chaps / chapettes - need a bit of advice about geo on some bikes i have ben looking at
Speech AWOL
Marin four corners
Genesis Vagabond
Kona Sutra
i am normally a 58cm TT and 200mm HT sort of guy i.e. 6'2 and inside leg 34
but a lot of the Large sizes i am looking at have a TT of 20+mm longer than i usually ride, i also appreciate the stems are shorter due to a more off road bias and therefore a more active front en but i need some help as to which sizes to opt for.
Genesis - looking at large 593mm TT but should i go for an XL with a 614mm TT ?
Marin - similar challenge - Medium has a 575 TT but the large has a 600m TT , but comes with a 70mm stem whereas i ride a 120mm stem for general gravel & road riding
any help appreciated
cheers
Posted : 26/11/2016 7:30 pm
Means little without seat angle/seat post/reach info.
Posted : 26/11/2016 7:36 pm
I'd go longer TT and shorter stem than a road bike.
Posted : 26/11/2016 7:41 pm
How are they meant to be ridden? What sort of terrain?
If you're just riding fire roads then I'd size it like your road bike.
A longer TT/wheelbase should feel a bit more stable if you're planning on hossin it over rough stuff.
Posted : 26/11/2016 7:50 pm
Just to put it this way, on my cx bikes I have 100 and 110mm stems and my home built "adventure" Monstercross I have a 80mm stem - I found the wider flared drops worked a lot better with the shorter stem and longer top tube
Posted : 26/11/2016 8:07 pm
OP-I'm the same height as you and would be looking at XL in the Genesis Vagabond and the Specialized AWOl.
Posted : 26/11/2016 9:59 pm
cheers all, and agree think XL is probably best or could put longer stem on the smaller one
Posted : 26/11/2016 10:54 pm
