Does anyone know where i can buy the thinner seatstay bearings so i can put a fox dhx on my spesh enduro '05. i bought it with a 5th element on but that has a thinner width to the eyelet body, (not spacers). i have read that i need the enduro sx spacer cup and ball which are 3.6mm rather than 4.5mm. any help would be much appreciated as i can't seem to find anything anywhere. cheers guys.
Betd should be able to sort you out.. Very helpful a few years ago when I changed the shock on my 05 enduro from fox to manitou..
All you need is a different spacer!
If you look at the set up you will see two larger spacers in a bronze kind of colour made of aluminium and two smaller stainless spacers that are angled.
You need a thinner version of the stainless smacer or you could use a bench mounted grinder to take some of the material of the spacer you have.
Good call getting rid of the 5th element they're not very good 😀
