hi guys i have a trek fuel 95,i have just returned from a ride today and the swing arm pivot is loose, i have removed the bolt and here is an aluminium sleeve in the frame which has a lot of play in it can this part be purchased or is my frame shot? thanks in advance
Gaz
Posted : 18/06/2011 8:17 pm
Sounds like this is what they call a bush, used instead of bearings. Any Trek dealer should be able to get hold of a new one for you and also fix into the frame for you. Wont cost much either.
Posted : 18/06/2011 8:23 pm
thanks ruscle i thought it might have been b0**0xed
Posted : 18/06/2011 8:28 pm
Take it out, wrap it in Gaffa tape...
Re insert...
Jobs a good un'.
Posted : 18/06/2011 8:31 pm
