Helmet mounting a S...
[Closed] Helmet mounting a Solar storm X2.
[#6815224]
What can I do that is better than my grip and zip ties. It wanders around too much.
Posted : 27/01/2015 9:20 pm
Mine came with an elasticated helmet mount. They are on ebay pretty cheap
Posted : 27/01/2015 9:32 pm
Here is my solution using gopro mounts. [img][url= https://farm6.staticflickr.com/5586/15136554430_4be3554e86_z.jp g" target="_blank">https://farm6.staticflickr.com/5586/15136554430_4be3554e86_z.jp g"/> [/img][/url][url= https://flic.kr/p/p4yNho ]Gopro Cree X2 Solar Storm Mount[/url] by [url= https://www.flickr.com/people/77014978@N03/ ]Matt The Hat 71[/url], on Flickr[/img]
Posted : 27/01/2015 9:38 pm
I use one of [url= http://www.magicshine.co.uk/accessories/magicshine-helmet-mount-mj-6028.html ]these[/url], holds securely and doesn't move while riding.
Posted : 27/01/2015 9:53 pm
I used an eraser, gut to shape and a long O ring to go round part of the helmet. The rubber stopped it slipping but kept it at the same angle. I did have a lot of odd shaped rubbers in my drawer at work for a while though.
Posted : 27/01/2015 10:38 pm
Here you go
http://m.ebay.co.uk/itm/221523237327?nav=SEARCH
Posted : 27/01/2015 11:19 pm
Heres mine ,another Gopro mounted one !
http://s1231.photobucket.com/user/Champs359/library/Solarstorm%20x2%20mount
Posted : 28/01/2015 12:20 am
Modified GoPro too.
One from the side too.
Posted : 28/01/2015 10:35 am
I've just put mine straight on top of my Specialized Vice helmet and used the o-ring to hold it in place around one of the "bridges" between vents along the centre of the top. Might not be the best explanation and I don't have any pics handy. But, it stays in place and is very low profile, so I don't smack it on low branches that I haven't seen.
Posted : 28/01/2015 10:51 am
Might sound like a daft question, but how is anyone using the elasticated straps listed above with a helmet, i got some with mine but can't work out how to securely use it and be in the right position.
Posted : 28/01/2015 10:59 am
Has no one created a reasonable low profile mount, as most of those ^^^ and the std mount would mean I'd lose my light under low branches.
Thought I might be able to using the Bell go pro mount.
Posted : 28/01/2015 11:07 am
markshires, I removed the straps and zip-tied the plastic mount to my helmet.
Like z1ppy, I used to use the elastic band directly to the helmet but my new helmet wasn't the right size.
Posted : 28/01/2015 11:48 am
Thanks flatpat,
That is what I was thinking of doing, but thought I must have been missing something with the elastic straps.
Posted : 28/01/2015 11:53 am
Strong velcro does the job. Never had an issue with mine
Posted : 28/01/2015 11:55 am
