Helmet Mounted Ligh...
[Closed] Helmet Mounted Light Cable Attachment?
[#8185907]
Guys as it says in the title, l have a GoPro mount on the front of my POC Receptor Flow, l am interested in options for attaching the cable from the light to the body of the helmet so that l can drop it off the back into my rucsac. I am thinking adhesive cable guides or similar?
Has any one out there got a cunning solution other than my thought above?
MUTDz
Posted : 29/11/2016 9:11 pm
you're over thinking it, a small cable tie or two is more than sufficient.
Posted : 29/11/2016 9:14 pm
Or if you want something more removable than a cable tie. Jnr seems to have a load of small, thin velcro straps with one of his mount packs. Would do the trick.
Posted : 29/11/2016 9:17 pm
Zip tie and o-ring is what I use on my Super 2R.
Posted : 29/11/2016 9:34 pm
Thanks Guys, you are right l was over thinking it, have got some small Velcro strips, O rings and zip ties so l am sorted!
Cheers MUTDz
Posted : 29/11/2016 10:19 pm
