Helmet light with g...
[Closed] Helmet light with gopro mount.
[#6610601]
Are there any small lights available that fit onto gopro mounts?
I've been messing around with a solarstorm x2 and various different ways of getting them to mate together.. Just wondered if there are any commercial versions available.
Posted : 05/11/2014 12:14 pm
I have a 3D printer and I print go pro mounts for my lights...
Posted : 05/11/2014 12:58 pm
how strong are the mounts that come out of a 3d printer?
Posted : 05/11/2014 1:40 pm
I guarantee you wont be able to break it through normal use. You will most probably snap the screw holding it to the light before the mount gives way.
Is that your setup in the picture?
Posted : 05/11/2014 1:49 pm
Thats an early attempt.. i have a couple of different alloy adaptors ordered to see which one works the best.. They are going to need the light to be drilled and tapped so that should be interesting
Posted : 05/11/2014 1:59 pm
Oh, how does the mount attach to the light at the moment? Let me know how you get on, I can send you a printed mount to try.
Posted : 05/11/2014 3:17 pm
I've never seen a commercial one but it's easy to adapt a standard gopro mount. I decided to go as low profile as possible so just got a gopro "foot" and removed all but the bit that slots into the sticky "shoe", then added a little wedge (made out of a clothespeg, bodge fans) and bolted teh light directly to that. No adjustability but that's OK, and keeping the light really low means it doesn't pull the helmet around as much
Posted : 05/11/2014 4:17 pm
SP POV Light is exactly what you describe. It's designed for diving with a GoPro (so is waterproof), and can have a GoPro mounted on top, so that the light sits in between the mount and the GoPro. Runs on GoPro sized batteries too, so easy to source spares to boost runtime.
Posted : 05/11/2014 4:32 pm
My Tiny Sun are about to launch one I believe- it's in the latest MBR.
Posted : 05/11/2014 4:34 pm
Lupine do a [url= http://www.bike24.com/p265988.html ]gopro mount for the Wilma[/url] that bolts straight to the bottom of my MTB Batteries Lumenator (the plate is 20mmx30mm with a hole for the m4 screw 8mm from one end). Works great.
Posted : 05/11/2014 4:44 pm
This looks like a cracking product idea. I don't own a GoPro, but I'd quite likely buy the mounts to use with my Solarstorms if they offered more security than the lashups I use at the mo.
A particular problem I see is helmet mounts that are too clunky, not stable enough or a combination of the two.
Posted : 05/11/2014 4:46 pm
bent udder - Member
I can make them very low profile. The base of my light is at the same hight as the helmet mount. And I make them so the light is fully adjustable in all planes. I suppose I could buy a solarstorm and make up some custom mounts if there is enough interest.
Posted : 05/11/2014 5:21 pm
This is how mine is mounted at the moment.. I have a mount coming that is very similar to the lupine one so i will give that a try. The lupine one would probably work fine with the solarstorm x2.. it looks about the right size..
Piesoup.. the dimensions of the flat part of the solarstorm are 41.71mm x 20.41mm. The screwhole is centered 13.10mm in from one edge along the 41.71mm axis. This is to the rear of the light. The twin prong gopro mount would fit in front of that
Posted : 05/11/2014 5:36 pm
Racewaredirect do mounts to fit exposure joysticks to gopro mounts.
Posted : 05/11/2014 7:10 pm
I believe glow worm x2 are releasing a gopro mount for their lights, or so the OH tells me!
Posted : 05/11/2014 8:01 pm
 SOAP
Here's my effort with a bit of sugru,this is the mk2 now with bolt. Mk3 will have a Ti bolt.
1/4 turn gopro mount from eBay £4
Posted : 05/11/2014 8:06 pm
My mounts make the light sit a lot lower. It sits in front of the mount, so the cable and switch will be either side of the go pro clamp. A lot less chance of snagging.
Haven't got any pics with me at work but can take a few tonight.
Gav, are these dims correct? Can you give me the centers of the switch and cable exit, and how far the switch sits proud please. Then I know how long I need to make the part.
[img] .html[/img]
Ahh, picture not working...
Posted : 06/11/2014 5:23 pm
Posted : 06/11/2014 5:45 pm
Thanks hot_fiat!!
Posted : 06/11/2014 8:33 pm
Knog do one
http://www.wiggle.co.uk/knog-qudos-3-led-action-light/
Posted : 06/11/2014 8:35 pm
Here is my light and mount. Mounts can be made into any config to suit your light.
[img] http://s3.photobucket.com/user/piesoup/media/Mobile%20Uploads/image.jpg.html ][IMG] http://i3.photobucket.com/albums/y59/piesoup/Mobile%20Uploads/image.jp g" target="_blank">http://s3.photobucket.com/user/piesoup/media/Mobile%20Uploads/image.jpg.html ][IMG] http://i3.photobucket.com/albums/y59/piesoup/Mobile%20Uploads/image.jp g"/> [/IMG][/URL][/img]
Forgive me, I'm on an iPhone and can't seem to get the img to work!
Edit: It worked!
Posted : 08/11/2014 6:30 pm
Wow - looks spot on! Reckon you could do one to fit Solarstorms, and if so, how much would you do 'em for? We have a printer at work - not sure if its guardian would let me tinker with it, though... 🙁
Posted : 10/11/2014 2:02 pm
Yes I can. Just confirm the dims I asked a few posts up and I can print one or two for ya. It will be white though as thats the only colour I have at the mo
Posted : 10/11/2014 5:50 pm
That'd be smashing. Trade for Haribo?
Will measure the bottom of the X2 tomorrow. possibly not as accurately as above, mind.
Posted : 10/11/2014 11:46 pm
Piesoup -
I'd be interested in one too if you are doing a run? I'm using a bell super helmet with the gopro mount on my SSX2.
Happy to bung a few quid your way or donate here (or to a charity of your choice)
Andy
Posted : 11/11/2014 9:37 am
Piesoup.. The only issue with that mount is that if your gopro mount is to the rear of the helmet you may not have enough downward angle to get the beam where it needs to be. If it sat slightly higher you would have more option..
Posted : 11/11/2014 11:10 am
[img] ?oh=11b128ccbbafddf9c3dcee2477740676&oe=551EEED7[/img]
[img] ?oh=37c8fb90a86a26b284c12199442aae1c&oe=54D554F5&__gda__=1423231120_dee4d4b26f9ad1499336da924053f344[/img]
[img] ?oh=5e8dbda9775151b7ebe879f186562297&oe=54D9590E[/img]
Posted : 11/11/2014 11:14 am
the mount i used is this:
http://www.ebay.co.uk/itm/GoPro-style-ridecam-Adapter-Mount-/141430382842?pt=LH_DefaultDomain_3&hash=item20ede860fa
If someone was to make a similar mount with the 2 prongs rather than 3 it would be much simpler. I just had to find a longer screw to hold it all together. It would probably have been easier to just remove the third prong that has the treaded section so that it worked with a standard length bolt...
Posted : 11/11/2014 11:24 am
The dims dont have to be very accurate, just so the button and cable don't
foul with the mount.
Gav, you can flip the mount to get the light to shine lower.
The beauty of a 3d printer, is anything is possible. If your mount sits more to the rear of the helmet, I can make the mount to suit. My light sits right in the centre of my lid, less stress on my neck.
How about I make a few different ones for you guys to try? All I ask is that the postage is covered? Funds are tight at the mo!
What size bolts are used on the solar storm? I'll need to know for the hole. Or would you rather I not drill a hole, then you can get the light in the perfect position to suit you.
Posted : 11/11/2014 1:29 pm
I've seen strength mentioned a few times, but no one considering if the mount will brake off in a crash or colliding with a branch.
Most helmet mounted lights can come off easily, my ayups for example are held with a rubber band that locates over a nub at the rear so the light can come off fairly easily. A nylon bolt would presumably offer a similar breakable point.
Posted : 11/11/2014 1:47 pm
Not wishing to hijack a thread but.....has anyone tried mounting a light and a Gopro to their helmet?
Would 1 to each side to balance the weight work better than trying to fasten them both on top?
Posted : 11/11/2014 1:52 pm
I use a Marwi helmet mount to mount my x2 works a treat
http://hoffmanamps.com/MyStore/perlshop.cgi?ACTION=enter&template&thispage=BikeLights&ORDER_ID=!ORDERID!
Posted : 11/11/2014 2:20 pm
spooky_b329 - Member
Just let me say, 3D printed parts are plenty strong enough if printed properly and used as designed. Like anything really.
I use a screw with a wasted portion, that snaps before the threads in the aluminium light housing are damaged. Other than the oring attached lights and the old L&M, I dont think any others have strain relief in their mounts. Easy enough to print a part of the mount that would break should you want it, but then the mount will be forever useless. I think he screw with the wasted portion is the way to go. I can supply the correct size screw / bolt too.
Posted : 11/11/2014 3:34 pm
Funnily enough, I made this video at the weekend:
Posted : 11/11/2014 5:43 pm
Piesoup - sorry - I owe you some measurements. I'll more than happily pay postage and provide feedback. Will drop you a mail.
One of the problems this solves, for me at least, is swapping lights between different helmets. With the usual velcro strap jobs, you need to position the light carefully, maybe unvelcro some of the padding - basically, it's a faff. And I have one lid with two central fore-and-aft beams, and one with a single central beam, so you need to mount the light differently for each lid. using a GoPro stick-on mount should make it a bunch easier!
Posted : 12/11/2014 1:53 pm
this is my effort
https://plus.google.com/108267992033991783465/posts/1SSgzsfueaq
Posted : 27/11/2014 10:37 pm
I like that!
Do you other guys still want some mounts to trial?
Posted : 04/12/2014 10:35 am
yes bud i'd like to try one out.
I have a troutlite can send dimensions/pics later if you need them but it has a flat base to glue/fix to..
mail in profile if you want to sort out details payment/post etc
Posted : 04/12/2014 10:56 am
andysmiff1 - Member
Likewise but I wanted the mount to be sacrificial in case I ****ted a tree with my head. There are a lot of low hanging trees where I ride.
I cut the elasticated straps off the 'headtorch' assembly that came with the SSX2 and cable tied the plastic part on to my Super using thin ties. Then just a case of using the rubber loop to attach/remove as and when.
Posted : 04/12/2014 11:06 am
can i ask why are you guys set on the go pro mounting? im guessing its because you have a go pro? or is it because its a really good mount. im a bit wary aboyt sticking anything to my lid.
on the flip side i reckon i can half the mount size and have a much better fixing system. fun this 3d printing mullarky
Posted : 04/12/2014 11:22 am
My Bell Super helmet came with a Go Pro mount.
I don't have a Go Pro but it would be nice to use the mount for a Solar Storm light.
Has anyone successfully bodged the mount that comes with the helmet to hold a light?
Posted : 04/12/2014 11:30 am
andybrad - Member
It's a [i]really[/i] good mount- light, stable and secure, very thin, and quick release. Removable too, it's just a 3m sticky pad. I use it because I had all the parts already but it'd still be a good option if I didn't (though, I wouldn't have thought of it 😉 )
Posted : 04/12/2014 11:38 am
richmtb - Member
POSTED 12 MINUTES AGO #
Yup - I've done it. Really happy with it. At work at the mo but will upload some pics later to this thread.
Also used a second super/go-pro mount and modified it with some sugru to fit the vent on my road lid, so have the same mount system on both lids!
Posted : 04/12/2014 11:46 am
carlphillips - Member
Posted 1 hour ago # Report-Post
shedbrewed - Member
Cool, send me any dimensions of the Trout light and Shedbrewed, can you send me the dims of the SSX2 as well. I'll knock up a few different ones with a wasted portion designed to shear at the weekend and send them out for you to try.
The plastic is easily filed, so if they are not quite right, you can file them to fit. Then if you want a re printed one, just show me what you have adjusted so I can redraw them.
My email is in my profile too.
Posted : 04/12/2014 12:07 pm
Bit late to the party but I'd also be very interested in this if that's ok?
Will get the light and mounts out and do some measuring/scribbling and try to work out a secure, low profile way of doing it.
Posted : 04/12/2014 12:13 pm
Page 1 / 3
