Helmet advice
[Closed] Helmet advice
[#11335719]
Hi
please can I appeal to the combined wisdom of the STW massive.
Weve just come back from the alps and have decided that we really should be using a full face helmet in the parks. However we also like riding outside the parks where a trail lid is more appropriate.
So do we buy a full facer and take 2 helmets and decide which one to use each day or get a convertible one that can be switched on a whim? Clearly there are pros and cons to both approaches from flexibility and only packing 1 helmet for the convertible to the full face probably providing a better protection.
Have others had the same dilemma and if so which way did I you go and why
Thanks
ChrisMAC
Posted : 13/08/2020 3:49 pm
 Yak
I have both. Mostly I am not in a bikepark, so wear a trail lid most of the time. For my odd bikepark trip I bought a 7idp full face when they were on sale. Bought the wrong size though, so bought twice, but my son was quick to nab the smaller one.
Posted : 13/08/2020 3:58 pm
I've a full face and a regular lid.  I've no issue with helmets with a chin bar, and I think they're a pretty good solution, but i just know that I'd either 1. forget to put it on, or 2. put it on wrong . I'm a dunce, so a proper full face is safer for everyone
Posted : 13/08/2020 4:00 pm
What do you mean by appropriate? and what is your existing full face helmet?
Stupidly I used to not wear my fullface anywhere in the UK as I didnt like the warmth of wearing it or the visibility, I then got a fox pro frame which has better visibility and ventilation and can happily wear it.
Posted : 13/08/2020 4:02 pm
I don’t have one at the moment hence trying to work out what the best solution is.
Posted : 13/08/2020 10:45 pm
I've just bought a bell super dh, does both jobs, detachable chin piece and passes the same CE tests as regular full face helmets.
Posted : 13/08/2020 10:53 pm
Flicker. Is it as good as the reviews suggest as that one I’m wanting to try for fit
Posted : 13/08/2020 11:11 pm
Very comfortable as a full face and a trail lid. The chin bar seems as strong as the bell full 9 I tried too.
Merlin cycles have the super dh in stock for £179, I bought a medium and large and sent the extra one back after I'd tried them both.
Posted : 13/08/2020 11:15 pm
As others say, two helmets, the changeable helmets don't fill me with confidence like a full facer does, and i dare say they'll be heavier and less comfortable than a normal helmet. You could always go middle ground and get a dropframe for less adventurous days, but it'll get expensive having a a couple of £200 helmets and your normal one!
Personally i just wear the full facer for uplift days, DH only days and stuff like that, where i can go slow on the ups and have the confidence on the downs, if i was doing full loops of several km's then i'd probably leave it in the car and use a normal lid, it's all about the risk on the day, but reality is that full facers aren't all that bad for some miles, i just don't enjoy the lack of peripheral vision for so long, that gets me more than heat or weight.
Posted : 14/08/2020 12:20 am
Thanks for your thoughts guys
Posted : 14/08/2020 12:34 am
I’ve just been through this.. I have a TLD D2 for uplifts that I’ve had for donkeys years. Great when you don’t have to pedal up (or even along..) but deary me on a warm day it’s like a bucket of fire!
I have a Giro Hex trail lid for normal non-uplift duties but have become increasingly worried of late about coming off and smashing my teeth, jaw, etc. as sometimes ride fast stuff and also some techy/steep descents.
I ended up getting a TLD Stage on sale for £180 (you often find certain colours/sizes are nearly £100 cheaper than others). It is a fantastic helmet. Really light, really well ventilated and the chin bar feels solid if not detachable. TLD and Giro are literally the only 2 brands that fit my massive (62cm) odd shaped dome so that cut down the choices I had to a large extent!
Posted : 14/08/2020 1:22 am
 aide
Got the bell DH, used to have the 2r but prefer the certification on the DH. Obviously heavier than the 2r and seems to run quite a bit warmer. However i am more than impressed with the helmet, have came off the bike and tested the helmet and can say with confidence that it works! If the bell fits your head/is comfortable then i would recommend it
Posted : 14/08/2020 10:53 am
