Helitape and sharpi...
[Closed] Helitape and sharpies.
[#5739009]
I have just had a frame that I received powder coated white and I intend on decorating it colourfully with the arty gf with sharpies.
I am hoping that helitape is the best way to protect the art work from coming off from washing and riding. Would there be any issues with applying it as the sharpie itself could be considered a "containment" and then the tape may not adhere very well.
My question is this, would having the frame drawn all over affect the adhesion of helitape? And if it does what is the best alternative method of protecting the frame?
Posted : 01/12/2013 10:05 pm
What's 'with sharpies'?
Posted : 01/12/2013 10:18 pm
[img] [/img] with any luck, something like this.
Posted : 01/12/2013 10:19 pm
Depending on the particular ink and glue combination, the ink might bleed a little under the tape. Probably worth a test on something and leave for a while to see if it blurs?
Posted : 01/12/2013 10:41 pm
Oh, so 'sharpie' is American for 'pen'?
Posted : 01/12/2013 10:46 pm
Sharpie is the brand of permanent market I have bought in tesco as it was on offer.
Posted : 01/12/2013 10:50 pm
like 'Biro' ?
(I like that white frame up there ^ )
Posted : 01/12/2013 10:52 pm
Max - slight illusions of grandeur?
Posted : 01/12/2013 11:02 pm
Could you put a couple of coats of clear spray lacquer on it or would that make the ink run?
Posted : 01/12/2013 11:03 pm
Dabble - thats why I am asking really, not sure what the best way to protect runs would be.
Oli - so many sharpied things that make it look lovely. I also bought a ridiculous 60mm DH stem for it today as well.
Posted : 01/12/2013 11:07 pm
These are Sharpies.
Posted : 01/12/2013 11:15 pm
Posted : 01/12/2013 11:16 pm
I'm pretty sure the solvent in lacquer will smudge/dissolve the sharpie - unless you can find a water based one as sharpies are supposed to be waterproof, but not solvent/alcohol proof ❓
clicky for similar topic elsewhere on the interwebs [url= http://forum.ukuleleunderground.com/archive/index.php/t-58616.html ]CLICKY!!!!![/url]
Posted : 01/12/2013 11:28 pm
 JoeG
Did you check the [url= http://www.sharpie.com/enUS/Pages/Home.aspx ]Sharpie website?[/url] Others have done similar stuff on there
[url= http://blog.sharpie.com/page/8/?sid=enUS ]motorcycle[/url]
[url= http://blog.sharpie.com/2008/11/bike-meets-sharpie/?sid=enUS ]bike frame[/url]
Posted : 02/12/2013 1:25 am
It's DELUSIONS of grandeur, not illusions. 🙂
Posted : 02/12/2013 9:17 am
[i]These are Sharpies.[/i]
Ecky Thump, anyone...
Posted : 02/12/2013 9:20 am
From that motorcycle article:
[b]Once you completed the finished design, what did you do to seal it?[/b] What type of sealant did you use? First, I applied three light mist coats of Dupont 622 Intercoat Adhesion Promotor. Then I let it sit for four hours to dry thoroughly. The final clear coat was Dupont g2 4500S Fast Activator.
Posted : 02/12/2013 9:40 am
Posted : 02/12/2013 10:28 am
