helicoil a crank ar...
[Closed] helicoil a crank arm?
[#815494]
ive stripped the threads on the pedal of my crank . can it be helicoiled or is it a case of new arms
Posted : 26/08/2009 11:28 am
why dont they use inserts on all crank arms?
Posted : 26/08/2009 11:31 am
 GW
chuck - coz there's no need!
Posted : 26/08/2009 11:38 am
But it just makes sense to me! I stripped the thread on the pedal bit of my last crank arms, new ones have a steel insert and just seems to make more sense to me!
Posted : 26/08/2009 11:39 am
If you can find a helicoil of the right size, sure.
Posted : 26/08/2009 11:40 am
cheers guys just wondered if anyone had done it to a crank arm
Posted : 26/08/2009 11:46 am
[url= http://highpath.net/cycles/special/repairs.html ]Highpath engineering[/url]
These people can do it for you.
Posted : 26/08/2009 11:54 am
 D0NK
Family friend got one of my cranks helicoiled at a local place years ago, sorry no idea on cost or where it was done but it worked and lasted a good while before I binned the cranks.
Posted : 26/08/2009 11:59 am
Most decent bike shops will be able to do it, I had one done for £14, £10 minimum labour charge plus £4 for the coil.
Posted : 26/08/2009 12:05 pm
See this also [url= http://www.singletrackworld.com/forum/topic/cranks-for-old-mercian ]Recoil thread[/url]
Posted : 26/08/2009 12:07 pm
yeah i agree with chvck it makes f all weight difference, should at least be on the higher end products. sure it will come in soon enough.
Posted : 26/08/2009 12:13 pm
I managed to rip the pedal out of my XTR cranks.
Pearce Cycles put an insert in for £15. It's a steel top hat bush rather than a helicoil. Cranks were on my DH bike and it's held up a treat.
http://www.pearcecycles.co.uk/
Posted : 26/08/2009 12:24 pm
 D0NK
F all weight difference? Or not enough for YOU to bother about tails? As mentioned I've stripped 1 crank in a lot of years of riding and that was down to user error IIRC. For heavy duty riding a good shout but for day to day riding probably overkill and definitley not for weight weenies.
Posted : 26/08/2009 12:27 pm
